    $79.99
    TICKR FIT heart rate armband uses optical heart rate technology to provide accurate heart rate and calorie burn data in the most comfortable form factor yet! Equipped with Bluetooth and ANT+ technology to seamlessly pair with fitness apps, smartphones, and GPS bike computers and watches. Worn on the forearm, the TICKR FIT heart rate monitor comes with an adjustable band that is designed for your most grueling workouts including running, cycling, fitness classes, and more. TICKR FIT has water-resistant technology and a rechargeable battery that lasts up to 30 hours.
    About the Tickr Fit
    CONNECT WITH CONFIDENCE
    TICKR FIT connects to smartphones, GPS watches & bike computers, and it verifies the connection by using convenient LED lights.
    ULTIMATE PRECISION
    TICKR FIT uses the latest in optical heart rate technology to give you accurate heart rate and calorie burn data for up to 30 hours.
    COMFORTABLE AND SECURE
    Made from advanced performance materials, TICKR FIT’s band is designed to fit comfortably around your arm, yet fit securely during intense activity.
    DUAL-BAND ANT+ AND BLUETOOTH TECHNOLOGY
    Both Bluetooth and ANT+ capabilities allow for a wireless connection to both smartphones and GPS bike computers and watches. Note: Does not serve as an ANT+ bridge.
    REAL-TIME HEART RATE, CALORIE, AND WORKOUT DURATION TRACKING
    TICKR FIT measures vital workout metrics, including heart rate, calorie burn, and workout duration in real-time with the Wahoo Fitness app. These metrics can also be sent to compatible third-party apps that track these metrics.
    LED INDICATOR LIGHT
    One LED light shows visual confirmation of the TICKR connection status via Bluetooth and / or ANT+: searching for a connections, connecting, and reading heart rate.
    USB RECHARGEABLE BATTERY
    Includes a USB rechargeable battery with up to 30 hours of battery life.
    ADVANCED PERFORMANCE MATERIAL STRAP
    Made from advanced performance materials, TICKR FIT is designed to comfortably fit around your arm, yet fit securely during intense activity.
    TWO ADJUSTABLE BANDS INCLUDED
    TICKR FIT comes with 2 adjustable bands (small and large size) in the box.
    APPLE WATCH AND APPLE TV INTEGRATION
    Connect directly via Bluetooth to your Apple Watch or Apple TV as another option for gathering heart rate data while you workout.
    THIRD PARTY APP COMPATIBILITY
    Works seamlessly with over 50 apps - including SYSTM, Zwift, Peloton for cycling and Runkeeper and MapMyRun for running.
    What's Included?
    • TICKR FIT unit
    • Small arm strap
    • Large arm strap
    • Battery charger
    Tech Specs
    • Part Number: WFBTHR03
    • Rechargeable Battery: 30+ hours
    • Strap Length: Small 10" x 1" (260mm x 25.4mm) and Large 15" x 1" (375mm x 25.4mm)
    • Water Resistant: IPX7 (waterproof up to 5 feet)
    • Sweat proof: Yes (hand washable strap)
    • On/Off Button
    • Not compatible with chest straps
    Click here for TICKR FIT instructions
